Re: engine miss- low compression on my 400
Posted by SDE on December 25, 2014 at 14:16:05 from (71.87.90.88):
In Reply to: Re: engine miss- low compression on my 400 posted by D Slater on December 25, 2014 at 12:31:10:
I do not think that it is leaking any coolant, any more. I will pull the plugs and check for coolant/wet pistons. It has started easily enough that I did not notice anything that should have broken any rings. If a cylinder had that much coolant in it, wouldn't it blow some of it out the exhaust? I have not noticed anything like that on the ceiling above the exhaust. Thank you
SDE
  Upload Photo  Select Gallery Photo  Attach Serial No List
