Re: engine miss- low compression on my 400
Posted by D Slater on December 25, 2014 at 12:31:10 from (184.14.166.249):
In Reply to: engine miss- low compression on my 400 posted by SDE on December 25, 2014 at 09:13:28:
Unless you pressure tested the head after repair its still questionable. If leaking into the combustion chamber it can damage the piston rings or break them on startup if enough fluid gets above the piston. Maybe the first thing to check is after siting overnight, remove spark plugs and see if coolant comes out any of the holes. If not try to move each piston to top and try to see a wet piston top. Depending on pistons that maybe can't be done with the eyeball.
You didn't say if coolant was running down inside of sleeve or outside. If outside you probably missed a crack.
  Upload Photo  Select Gallery Photo  Attach Serial No List
