No need to split tractor. Remove clutch to get shaft out of the way. Then take out the six bolts holding cage in and pull input shaft assembly out. You need to pull belt pulley assembly off to reinstall assembly to guide pilot bearing into shaft. Doing the job this way will give you the important opportunity to asses the condition of that pilot bearing as it is theeeeeeeee weakest link in the whole transmission along with properly replacing worn bearings and seals.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
