H Tranny Input Shaft Bearing Replacement
Posted by Oregon Tractor Jack on December 25, 2014 at 14:38:56 from (50.137.138.152):
Can the transmission input shaft bearings be replaced with out splitting the tractor or removing the transmission cover? I have the pump out and was just planning on changing the transmission seals, but I find the input shaft has a lot of play. I assume the at least the front bearing is toast and most likely both are. That one looks like it could be changed with out a split. The inner one what I am not sure of.
Thanks,
Oregon Tractor Jack
Oh, Merry Christmas and a Happy New Year!
  Upload Photo  Select Gallery Photo  Attach Serial No List
