Re: farmall 200 resistor
Posted by Janicholson on December 25, 2014 at 18:29:02 from (74.60.94.18):
In Reply to: farmall 200 resistor posted by Ramp;W on December 25, 2014 at 11:19:51:
No wiring needs to be changed, but the gen will just barely do any charging at all and would need a positive ground 12v voltage regulator. It can overheat the gen field windings, and will not keep up with lights or Idling. Work tractors need real charging systems. These tractors easily start on 6v, so the least expensive is to put in a new battery. 12v with an alternator is best and cheaper than buying a quality 12v regulator. Using a Hitachi alt is easiest, or a Delco 10SI alt. Both pretty cheap and usually with a lifetime warranty. Going to a 12v generator is OK but requires more money than any other option. decide and we can talk you through the install. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
