Re: H Tranny Input Shaft Bearing Replacement
Posted by Owen Aaland on December 26, 2014 at 13:50:29 from (216.47.34.37):
In Reply to: H Tranny Input Shaft Bearing Replacement posted by Oregon Tractor Jack on December 25, 2014 at 14:38:56:
If you remove the flange from the transmission input shaft you can get the input shaft and carrier assembly out without removing the clutch shaft. Also the transmission input shaft bearing can be replaces without removing the belt pulley or cover. On the other hand, doing it Pete's way may be easier if you are not familiar with how the tractor is built.
