Have you given the manifold and carb gasket a propane check? Pull the choke out so as to get it only barely running at idle. (not running well, too little choke). Use a unlit propane bottle (with the nozzle unscrewed from the torch handle so it gives out only propane, no air) open the valve on the bottle ao it would be a good flame (not wide open) and use it around the manifold to see if it perks up. if it does, it has a leak at that spot. Make sure the idle jet screw has not been twisted off in the body. Jim
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati
... [Read Article]
Latest Ad:
[More Ads]
