Frustrated in So. Indiana with cub
Posted by Mpriar on December 27, 2014 at 13:21:19 from (166.137.10.75):
I have an international loboy. Great little machine...but
Will not idle. Here is what I have done. Cleaned carb several times, every oriface,every part, all of it, looks new.
New points,condensor,cap, rotor,plugs,set timing. Checked fuel flow, it will run out gallons at full stream, no filter. Put new manifold gasket on. Cleaned air filter. Will start and run fine on 1/2 choke. When choke off, dies at idle, but will run with no choke at higher rpm. Checked compression, 120 at each cylinder. After it dies will start right up with choke.
HELP HELP HELP, GOING CRAZY!!!
  Upload Photo  Select Gallery Photo  Attach Serial No List
