I had the same problem with an H carb that I rebuilt. Had it apart three or four times, cleaned and cleaned and it still wouldn't idle. Finally on the last time apart, I took my torch tip cleaner and poked all of the holes I could find and blew it would with compressed air. Then I did the entire process again! That finally fixed it. To really clean a carb you need to pull out all of the jets too. You may think you have it cleaned out, but I bet there is still an air passage that is plugged up.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
