Re: Just bought an A
Posted by FBH44 on December 28, 2014 at 03:30:32 from (64.85.214.223):
In Reply to: Just bought an A posted by crebellocfd on December 27, 2014 at 17:09:01:
Well since you asked .....
1. If it ain't broke, don't fix it. Seriously.
2. Go get some peanut butter jars, the clear plastic kind, the Peter Pan kind like, and clean them up, and save every EVERY nut / bolt / lock-wire / piece / part you remove to work on. The old dot bolts are especially cool. And somewhat valuable. I fojnd on my Farmall H the tapered clutch pivot part bolts are VERY valuable, about $45 each, .... save every piece and part. You'll be glad you did.
  Upload Photo  Select Gallery Photo  Attach Serial No List
