Just bought an A
Posted by crebellocfd on December 27, 2014 at 17:09:01 from (73.47.52.186):
Hello all , brand new to this forum. I just picked up a farmall a to help me on my land. I have a few questions for you guys.
If the tractor runs fine , should I order the magneto rebuild kit or just leave it be ?
Where is the full plug for the transmission , as the gearbox has a small leak and loses fluid?
It seems that my starter doesn't do too well, it smokes when it's held in to start the tractor , when it does work the tractor runs great with no problems .. I took off the band around it where you can see inside of it and I can see the wires heating up and melting , I ordered a new starter in hopes that it will be just fine
