Posted by gene bender on December 28, 2014 at 05:26:17 from (67.55.226.121):
In Reply to: Just bought an A posted by crebellocfd on December 27, 2014 at 17:09:01:
Those mags are usually trouble free if it starts and runs nothing is needed. But you do ned to remove the starter and get it refreshed an easy fix. You new one probably wont work unless you do get the correct one too many are listed as replacements but arent fitted with the button for the starter sw. Your fluid level for the tranny is located behind the brake rod on the left side of the seat. Drain and refill with 90wt
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
