Re: Just bought an A
Posted by DeltaRed on December 28, 2014 at 08:04:23 from (65.100.146.228):
In Reply to: Just bought an A posted by crebellocfd on December 27, 2014 at 17:09:01:
All comments/suggestions are accuret/correct.But I
would add couple things. Since you are a 'newbie'(no
offence),order an owners manual,a parts book and a
service manual.On the starter issue, Be sure and
replace the cables with new ones of sufficent size
to carry 6 volts.Then hook the ground directly to a starter mounting bolt Those thin automotive cables wont
carry enough 'juice' for 6V. thin cables can also
cause premature starter failure and other starting
issues.Good luck and enjoy your 'new' old tractor!
  Upload Photo  Select Gallery Photo  Attach Serial No List
