Re: ATF as hydraulic fluid?
Posted by Lee K. on January 09, 2001 at 18:47:31 from (205.160.206.85):
In Reply to: ATF as hydraulic fluid? posted by brian on January 08, 2001 at 07:21:55:
ATF is used in a lot of skidloaders. I've heard of it used in other eguipment as well. Although I do use Hy-Tran in my 77 ford truck for tranny fluid. It works great. Use Hy-tran for power steering too.
Post A Followup
: Re: Re: ATF as hydraulic fluid?
