ATF as hydraulic fluid?
Posted by brian on January 08, 2001 at 07:21:55 from (152.163.205.58):
Has anyone tried using ATF in a loader hydraulic system? Mine is used mostly in cold weather plowing snow. The substitute that TSC sells for Hy-Tran is rated at 10W-20. I'm sure that ATF is thinner than that and would flow better. It's used in power steering and that's a hydraulic system, right? How about it guys? What do you think would be the good, bad, and ugly of this idea?
Post A Followup
: Re: ATF as hydraulic fluid?
