Re: Just bought an A
Posted by crebellocfd on December 28, 2014 at 15:44:11 from (73.47.52.186):
In Reply to: Just bought an A posted by crebellocfd on December 27, 2014 at 17:09:01:
Thanks guys for the help
I am a full time firefighter , not a mechanic lol but I can turn a wrench once I know what I'm supposed to do.
As far as the leak , it's a gasket between the gearbox and the transmission , so I should probably fill through the plug on top of the gearbox ?
With using your advice I will leave everything that is fine alone ! I'll just change all fluids, clean her up and use her like she craves !
I will have many questions as I go , I will probably email you guys individually instead of flooding the forum , thanks again
