Re: New to me Hydro 70 questions?
Posted by tractorsam on December 29, 2014 at 16:11:38 from (142.177.130.197):
In Reply to: Re: New to me Hydro 70 questions? posted by pete 23 on December 29, 2014 at 11:17:05:
As I'm unable to deadhead a valve I've taken the cover off beneath the seat. With the tractor running I get a slight increase in oil level from no obvious source and a barely detectable flow in the oil. To the right of the tractor I see the control valve? With the draft lever at 'light' the square block to the rear of the valve doesn't move when I move the position control lever. With the draft lever in the center position or ahead of center (to heavy) moving the position control lever results in a proportional movement of the square block in the same direction. I don't know if this helps but it's all I can see. Thanks, Sam
  Upload Photo  Select Gallery Photo  Attach Serial No List
