Posted by D Slater on December 29, 2014 at 19:38:41 from (184.14.166.249):
In Reply to: Re: 1943 M engine posted by farmboy48 on December 29, 2014 at 19:10:07:
Sounds like one they ground the original block casting number off and stamped in another number. If it has C-264 its a 1952 or newer. Unless the plate is attached to a hydraulic pump I don't know about it. unless its a rebuilders plate. If you look under the engine oil fill cap and the screen plate is retained by the stud the oil cap goes on its most likely a late cover. From the c 264 following just above that level toward the front of block you should find a date code. Like 4.12.X or different numbers or higher letter.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
