Re: 1943 M engine
Posted by farmboy48 on December 29, 2014 at 19:10:07 from (208.107.15.166):
In Reply to: 1943 M engine posted by D Slater on December 29, 2014 at 18:35:28:
Thanks, the raised (cast) number above filter is C-264, there are no numbers stamped on either of the raised flat areas, however above the C-264, the number 357665 is stamped into block. No plate behind carb, but behind dist drive housing there appears to be a small plate about 3/8's by 1 1/2 in with 4 23 B on it with raised numbers. Does this mean anything to you, I have no reference material yet.
thanks
Dick in ND
