The belt is the first thing I checked and then tighten up. As for the meter I have used it in the past to test charging systems and this is the first time I have had readings like these so I think it is this tractor not the meter. As in the charging system is in fact charging at to high a voltage. The other day I had to do some wiring on it because the ignition system was not working so rewired the ignition system with a ballast resister and since the fuel pump worked when the key was turned on just tapped into that to make the ignition work
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
