Re: 1943 M engine
Posted by farmboy48 on December 30, 2014 at 19:41:47 from (208.107.15.166):
In Reply to: 1943 M engine posted by D Slater on December 30, 2014 at 19:17:33:
thanks D for all your help, think I will try for the pump, and assume for now since it is a later engine that it has the heavier gear when it was built up. And if it fails I can then replace gear. Only money (grin) and I can use the tax write off, if I actually use it on the farm. Again, really appreciate your help.
I will probably have more questions later.
Dick ND
