Posted by D Slater on December 30, 2014 at 19:17:33 from (184.14.166.249):
In Reply to: Re: 1943 M engine posted by farmboy48 on December 30, 2014 at 17:53:30:
Front cover needs to be removed to tell what gear. First type had 4 numbers on it ending with a D suffix. Its weaker than the other 2. next one used until the middle fifties had a DA suffix. IH last design had a DB suffix. Think J.A.N. made a mistake about aluminum teeth. Can't answer about the loader. Depends on the size of the cylinders on how fast it will lift or how much lifting power. You can also tell what size front cover you have by the center to center distance apart of the top two bolts retaining the ignition drive housing. Can't remember the measurements without looking.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
