Re: converting M from 6 volt to 12 volt
Posted by Janicholson on December 31, 2014 at 12:13:18 from (199.17.6.28):
In Reply to: Re: converting M from 6 volt to 12 volt posted by David G on December 31, 2014 at 07:34:15:
Easier to use a double throw double pole switch. when "up the mag wire to ground is open, and a wire from the amp gauge to the switch then to the alt is on. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
