A one wire alternator is the easiest way to do this, but I have been thinking about how to do it with a 3 wire and one switch when using a mag. You could change the switch out with a normally closed one, then power a small automotive relay when the switch is out. The grounding terminal on the mag could go through the normally closed contacts on the relay.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
