Posted by J in Pa on January 02, 2015 at 18:57:08 from (24.239.59.69):
howdy all. just one quick question. i've been reading on here about the T/A and lube. being hy-tran is the way to go and using 80-90 weight gear grease will ruin the T/A. would someone explain why using 80-90 gg will ruin the T/A. thanks. J in Pa
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
