Re: T/A and lube
Posted by pete 23 on January 02, 2015 at 19:19:19 from (74.33.82.245):
In Reply to: T/A and lube posted by J in Pa on January 02, 2015 at 18:57:08:
The overrunning clutch (ramp and rollers) are in a wedge shaped groove. A small spring & plunger push's them to stay in contact with the TA planet carrier. The heavy gear lube hampers the free movement of those rollers and thus they do not maintain sufficient contact and then the carrier will spin against the rollers and you have a no drive situation in the low side of the TA and the rollers get flattened. It does not harm the planet gears themselves.
  Upload Photo  Select Gallery Photo  Attach Serial No List
