Posted by AndrewFromNS on January 04, 2015 at 15:28:32 from (24.224.255.133):
Hello!
A brief history....
I have a 1954 Super C, with a 10SI 12-volt conversion. I'm running a ballast resistor in line to the coil. THe Ammeter in the base of the pedestal is present, connected, but non-functional...the glass separated from the gauge a year or two ago, and I haven't got 'round to doing anything about it just yet. The factory push-pull ignition switch, due to a failure, has been recently replaced with a toggle switch. And I have an hour meter, and LED charge indicator light, mounted in the "dash" off something like an H, which is mounted to the lightbar.
Now, the problem...
This tractor has been wired and operational in this way for 6+ years now, and has never done me wrong, beyond the usual tune up, points cleaning, etc.
When the push pull ignition switch stopped working, I bypassed it by using a jumper wire from the positive terminal on the starter to the after-resistor side of the ballast resistor. This worked fine for quite some time (That switch has been on the round to it list for probably a year now). During this time, the hour meter always counted hours, the charge indicator always functioned as per usual, and the lights worked.
Very recently, while the tractor was staying with a friend of mine, he replaced the ignition switch for me with a conventional toggle switch. He reported at the time that it was business as usual, everything functioned as it should, and we no longer needed to use the jumper wire.
Fast forward to the last couple days. My friend was making ready to move the Super C back to my place, as its my snowplow tractor and, surprisingly, we were calling for our first real snowfall today. He mentioned that, for some reason, we no longer had functional headlights, but didn't figure he'd have time to troubleshoot it before he dropped it off.
So tonight, with a foot of snow on the ground, and in the pouring rain, I was trying to make some headway into determining whats causing my problem. All my connections are tight, all wires appear to be intact. The toggle switch no longer has any effect on any electrical function whatsoever. If I use the jumper wire to bypass the switch, the tractor starts and runs as it used to, but I have no lights (which I used to), and no charge indicator (which I used to), but the hour meter still counts time. If I take another jumper wire and go straight from 12V to the back of the light switch, I can get the lights to come on bright, but not dim. I attempted to bypass the ignition switch, by bridging the terminals on the back with a jumper wire, but that had no noticeable effect either.
Im certainly no electrical engineer, but this also isn't my first rodeo, I'm just coming up at a bit of a loss as to what could have failed.
Sorry for the long winded post, but I could use the help, and I know the more information I can provide, the better the odds someone will be able to point me in the right direction.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
