Re: F-12 oil pressure is too high
Posted by kstractor on January 09, 2015 at 20:42:49 from (166.181.80.110):
In Reply to: F-12 oil pressure is too high posted by Kevin LA-CA on January 09, 2015 at 19:34:57:
Better change the gauge first some of the 2 cyl. Deeres only had 7 psi for normal psi.
  Upload Photo  Select Gallery Photo  Attach Serial No List
