Re: F-12 oil pressure is too high
Posted by steelfronts on January 10, 2015 at 06:16:05 from (64.186.50.66):
In Reply to: F-12 oil pressure is too high posted by Kevin LA-CA on January 09, 2015 at 19:34:57:
some of those oil filter bases have a big nut holding the check spring and ball on its seat shims may be required under that nut to adjust pressure
  Upload Photo  Select Gallery Photo  Attach Serial No List
