Re: F-12 oil pressure is too high
Posted by Ron W on January 10, 2015 at 12:43:34 from (66.227.253.192):
In Reply to: F-12 oil pressure is too high posted by Kevin LA-CA on January 09, 2015 at 19:34:57:
I have rebuilt several f-12/14s. When I do a rebuild, I also rebuild/regrind the oil pump clearance. New everything. I usually get 60-80lbs pressure after a rebuild. I have one f-12 that gives 100psi and I have swapped five oil filter bases (where the pressure relief is located) as well as rebuild several oil pressure reliefs. Still 100lbs. I think I got the clearances too close.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
