Re: F-12 oil pressure is too high
Posted by Tom Fleming on January 10, 2015 at 19:11:03 from (67.20.239.72):
In Reply to: F-12 oil pressure is too high posted by Kevin LA-CA on January 09, 2015 at 19:34:57:
in the F series tractors, only the F12/F14 were pressure lubricated to the crank and mains. The Regular, F20, and F30 were all roller bearings and splash lube to the connecting rods.
So, the F12/F14 will run oil pressure higher than the other F series tractors. In fact, they are in the same range as the Letter series. The F12/F14's took a different gauge than the F20/F30. Think about your post. You are using a JD gauge on an IHC engine. Get the right gauge.
