Re: IH 606 Hydraulic pump upgrade
Posted by pete 23 on January 10, 2015 at 20:03:18 from (74.33.82.245):
In Reply to: IH 606 Hydraulic pump upgrade posted by gqjoe on January 09, 2015 at 22:29:32:
Seal is not sold separately so you get tube with seal on it. They always used to come with a chart showing the depth to move the seal to but I just measure the pump and depth shoulder is inside the transmission case and figure it out. I leave it a little long so when you install pump with tube inserted in pump the seal will be pushed to the correct distance when tightening pump down. The old part numbers will convert over to a new part number so which ever one you order you will get right one.
  Upload Photo  Select Gallery Photo  Attach Serial No List
