Re: probably for Gene Bender Farmall exaust lift
Posted by gene bender on January 10, 2015 at 20:34:29 from (67.55.226.121):
In Reply to: probably for Gene Bender Farmall exaust lift posted by HenryO on January 10, 2015 at 07:46:59:
Conveyer belt will not work as it has threads and you will not be abl to bend it across the piston. I get leather and make new ones all the time. 9in circle then cut out the center so it fits the piston. Then rub neats foot oil to get it nice and soft. Then fasten it to the piston and use a hose clamp to form it around the edge. You need to get the thickness of the leather so it will fit into the cycl wall. I have some new ones from I-H if you want one.
  Upload Photo  Select Gallery Photo  Attach Serial No List
