Farmall 230 hydraulic pump
Posted by cj3b_jeep on January 12, 2015 at 12:36:24 from (131.123.222.90):
I'm working with a farmall 230 hydraulic pump, part # 384506R94 on this site. This is an original pump not a new one.
This pump is mounted to the crank of the F134 engine in my CJ3b Jeep. I bought it used off a guy condition unknown.
When I first got it all together, it leaked like crazy, but did put out a bit of pressure to lift my three point hitch.
I replaced the shaft seal and put it back together, now it does not pump at all. Not sure why.
I did thane the main shaft/gear out and polish it with emery cloth. Is it indexed some how?
Could the over pressure/dump valve be stuck open?
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
