Re: C123 build
Posted by bass on January 15, 2015 at 10:59:00 from (208.54.175.117):
In Reply to: C123 build posted by Cliffton D on January 15, 2015 at 10:42:46:
im going thru my c123 right now and its 3 1/4 over bore the only problem ive had is finding the rings for the flat head pistions. i had to have them made. if you have flat head pistions ive got the part# for them. other then that, im having no problems
when i tore down the motor it was already bored to 3 1/4
