Re: International 444D question
Posted by jimb2 on January 21, 2015 at 15:09:34 from (99.241.118.87):
In Reply to: International 444D question posted by Jim 777 on January 21, 2015 at 14:02:53:
Hi Jim, first don't force the engine or you
could bend a rod or even worse. Most likely
possibility is a leaking head gasket allowing
coolant to fill an engine cylinder causing
hydro locking. Easy way to test for hydro
locking on a BD-154 is to remove the glow plugs
and see if any coolant runs out and then
attempted to turn engine with starter while
holding clutch pedal all the way to foot rest.
JimB
  Upload Photo  Select Gallery Photo  Attach Serial No List
