Re: Farmall H surging under load
Posted by Cory Schmidt on January 23, 2015 at 17:31:05 from (64.246.253.39):
In Reply to: Farmall H surging under load posted by badfarmallh on January 22, 2015 at 16:48:48:
Another thing to think about are you sure its the engine? Might be clutch. If the clutch holds and slips occasionally, the gov. may respond when it drives again. If you notice a loss of drive/traction, yet engine stays fairly steady(maybe governed perk) check the clutch adjustment.It could slip fast enough not to even notice loss of drive. Just another shot in the dark.
This post was edited by Cory Schmidt at 17:32:40 01/23/15.
  Upload Photo  Select Gallery Photo  Attach Serial No List
