Farmall H surging under load
Posted by badfarmallh on January 22, 2015 at 16:48:48 from (216.49.50.118):
OK guys looking for some words of wisdom here, I have a 1948 H. And I cant get it to stop surging under load, the linkage from the throttle lever to the gov housing is in good shape, I took all the play out of it, checked the stops on the gov. adjusted per the manual, the weights move freely, and the assembly slides back and forth. I see posts on here about fuel issues, so ... fortunately I have second H. I swapped carbs and the problem did not change at all. I really think I am missing some type of issue in the gov. I also have installed a rebuilt distributor, checked timing and advance, and everything seems to be working well. Id like any ideas, im out of both good and bad ones.
  Upload Photo  Select Gallery Photo  Attach Serial No List
