Re: Just bought an A
Posted by Jim Becker on January 24, 2015 at 21:17:44 from (74.34.166.95):
In Reply to: Just bought an A posted by crebellocfd on December 27, 2014 at 17:09:01:
You located in south Florida? The cooling system holds about 13 quarts. A half gallon of antifreeze only gets you down to about +25.
Since there is no water pump, it will not mix easily in the engine. Drain the system then premix in a bucket.
If you are someplace really cold, blocking air flow through the radiator will help keep the engine temperature up.
