I am a cheap skate. I would start with the oil pump. Remove the bottom cover of the pump. The gears will have worn grooves into the cover. This increases the clearances and reduces your oil pressure. Put sandpaper on a smooth level surface and set the plate or the sandpaper. Lightly push down on the plate and rotate it in both circular and linear motions until it is smooth. Re-install the plate on the pump. As long as the pump is moving enough oil to the moving engine parts, you should be ok. If pressure improves, you should be good until you have the time to rebuild the engine. SDE
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
