Re: farmall 200 rod bearings?
Posted by Janicholson on January 25, 2015 at 09:41:44 from (74.60.94.18):
In Reply to: Re: farmall 200 rod bearings? posted by SDE on January 25, 2015 at 09:05:42:
I concur. The oil pump has historically been an issue. Flat sanding it is easy. Clearance is very small.0005 to .001" (gaskets are the adjustment they are way thin. Jim.
  Upload Photo  Select Gallery Photo  Attach Serial No List
