Posted by jimb2 on January 26, 2015 at 13:24:36 from (99.241.118.87):
In Reply to: Case-IH 695 posted by Phil W in Michigan on January 26, 2015 at 05:00:54:
Hi Phil, yes, the small rad in front of main rad is an oil cooler for hydraulic/transmission oil. The oil cooler should have a thumb screw that will allow it to swing out of the way to clean the main rad. They main rad is difficult to clean out the air passages as I recall rad cooling tubes are staggered making the air swirl around the tubes. You have to use an air gun, blowing from the fan side first then from the front side. Also clean the air cleaner filter. Other possible causes of over heating: 1) Thermostat stuck closed 2) Rad core clogged with lime 3) Water pump
After engine has warmed up, rev engine to about 2000 RPM and look at bottom rad hose to see if it is collasping.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
