Posted by Phil W in Michigan on January 28, 2015 at 06:04:22 from (50.192.111.89):
In Reply to: Re: Case-IH 695 posted by jimb2 on January 26, 2015 at 13:24:36:
Thanks Jim. That is all good information. I pulled the radiator and oil cooler. The radiator was pretty calciumed up inside as well as being clogged between the oil cooler and the radiator. '
So the radiator is in for a re-core $500 going to have the oil cooler combed and flushed for another $100. That should help a lot. Now I have to figure out a pre-filter arrangement.
Now that I know how easy that oil cooler comes off I can clean that area better.
Between the loader and the bolt on hood that area is not very accessible.
I am going to replace the thermostat and hoses while I am in there. The hoses were pretty bulged out at the ends. Hopefully it will be running cooler after this work.
I will check the bottom hose also.
Do you (or anyone) know if there is a coolant filter in this tractor. I am going to change all the filters I find on it. But I was wondering if there was a filter and I will make sure I change that too. I can't find my manual anywhere for this tractor.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
