White smoke from 49 M?
Posted by unioncreek on January 27, 2015 at 16:56:42 from (72.171.192.119):
My 49 M mostly sat for the last 3 years with no use. It had a
hole in the radiator so I fixed that. I remember three years ago
when I used it that it got hot from low coolant. I used it today
and when it's at full throttle it runs good no white smoke. But,
at idle to about half throttle it smokes white and sometimes
quite a it. I'm thinking either a bad head gasket or cracked
block/head.
Anyway to tell?
Bob
  Upload Photo  Select Gallery Photo  Attach Serial No List
