Re: White smoke from 49 M?
Posted by dej(Jed) on January 28, 2015 at 04:51:27 from (141.189.113.1):
In Reply to: White smoke from 49 M? posted by unioncreek on January 27, 2015 at 16:56:42:
Check the oil to see if it is milky colored or gray. Also check your coolant level to see if it is going down. Additionally check your spark plugs. I am thinking that you probably checked the fuel. Ethanol can cause issues too. An M engine will take an awful lot of abuse, so it would have to have gotten super hot to warp the head or crack a block.
