Re: Connect battery wrong
Posted by old on January 29, 2015 at 09:23:05 from (209.86.226.40):
In Reply to: Re: Connect battery wrong posted by Larry Hardesty on January 29, 2015 at 08:00:23:
Alternator is in fact bad and was the moment you hooked up the battery. As for spinning over check your battery cables and make sure one or both are not burned out or has a poor connection. Plus depending on how it is wired it could be a simple wire going to a solenoid. Since we can not see it hard to know for sure. Yes I know most A use a push button starter type switch
  Upload Photo  Select Gallery Photo  Attach Serial No List
