Re: Connect battery wrong
Posted by gene bender on January 29, 2015 at 11:19:08 from (67.55.226.121):
In Reply to: Re: Connect battery wrong posted by old on January 29, 2015 at 09:23:05:
The A has the push sw mounted on top of the starter no push buttons only if someone rigged something wild and even changed starters that had a threaded stud instead of the button.
  Upload Photo  Select Gallery Photo  Attach Serial No List
