Re: Farmall 240 Utility Hydraulic Pump
Posted by luckytx2001 on February 01, 2015 at 11:13:39 from (69.27.137.130):
In Reply to: Farmall 240 Utility Hydraulic Pump posted by IH fan on January 31, 2015 at 13:38:28:
Thanks for getting back so soon. Spent entire morning with Google Search looking at Pesco, Thompson, and Cessa/Eaton; using about six different parts numbers. There is not much out there regarding the pump parts. I also had no luck with the repair kit part number, which probably has been superseded at least three times now. Some good news in that I was playing with the "back end" (photo #1) and found a second part number stamped on the body: 368633R92, which one web site indicated was superseded by:376993R94. Didn't help me my search, though. I feel like I shall probably pursue the Speedi fix, but hope you guys will stick it out a little longer. I measured the diameter of the gear that fits through "front end", and it was 15.4mm from top to bottom. There was slight discoloration on the shaft, but no grooves or nicks. I tried to measure ID of the sleeve or bearing itself but it was in pretty bad shape. Best measure was was 16.7mm. IS THAT LEATHER, RUBBER, OR JUST BURNT OIL ON THE INSIDE OF THE METAL BEARING? See con't on reply to HAL.
