Re: Farmall 240 Utility Hydraulic Pump
Posted by farmallhal on February 01, 2015 at 11:36:18 from (76.2.169.99):
In Reply to: Re: Farmall 240 Utility Hydraulic Pump posted by luckytx2001 on February 01, 2015 at 11:13:39:
I spent a couple hours last evening as well and obtained a little more information. The 376993R94 has been replaced by 1949256C1 which is currently available from CaseIH at a cost of $985 per Messicks website. That being most likely out of the options to consider I also found the aftermarket Thompson pumps available in several places under one of the numbers you have or I provided above in the $500-$600 range if you are looking for a total new pump replacement. I'm sure a repair will be far less expensive and a very doable fix to your stated problem. I also found where used/salvage pumps have been on eBay within the past couple of years so keeping an eye there is an option as well, Hal.
  Upload Photo  Select Gallery Photo  Attach Serial No List
