HAL con't. Gear pockets look great. Hal, ur comment about spring and ball got me re-looking at the pump. New photos 4 and 5 show opposing ends of the short gear. There is a spring inside the shaft. One end shows the end of the spring where it is crimped to hold in place. last pix shows other end where you can see a spring. Just room enough for a small ball. Is that the item I dropped on the shop floor, and can't find now? Do u both think it would be best to drop off the front end and gear to a shop, and let them figure it out. Final question for now. How did 3 gallons of trans fluid get through that 1.3mm gap between the shaft and bushing? Am I missing something more important? Thanks again for both of your guys help. Will keep you posted after I find that damn little ball!
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
